header bolt size o2 sensor
I know have my haeader and complete exhaust put on the car.......but I can't start it yet because of the nice size hole where a 02 sensor goes. Does anyone know waht size it is. 18 mm 5/8 and 16mm won't fit. I'm assuming it could be 17 but I couldn't find it anywhere so far.
Thanks for any help.
- manoa matt
Mark,
I have a 1980 carbureted model. 2l block, 1800 head. performance cams, 34 adf.got the header from iap. it's the injected header with the lambda port. the rest of the exhaust from Bruce's. Matt had mentioned a bolt from the cat converter. I will have to check my work tomorrow. put the whole exhaust in our scrap metal bin. My neighbor runs a tire joint/garage. he said he will find something as well. hopefully after tomorrow I should figure out something.
well....still no luck. my neighbor says he can get me a 18mm self tapping to put in there. rather not do that if I can help it. I mentioned o2 sensor but its the lambda for the injected models. not sure if 02 and lambda are the same thing.
a couple of mechanics at my work said to go to a plumbing supply house, they figured I could get a plug for it there. they said it might be pipe threading. I'm ready to try anything at this point.
Hey mark, called them up. it was probably the 3rd or 4th call. finally got hold of someone who knew what he was talking about. he looked it up in the system.......said they sell the plug for it!!! unbelievable! Thats unbelievable in a bad way. he said it should be here in about two days. we will see if it works. I appreciate the help. it's nice to be able to get hold of people who have serious knowledge of the fiat automobile.
This is my 5th that I have owned. three x19's and two spiders.
