oil seals
oil seals
Over the years, I've had varying luck with oil seals. Some that I've done and some that were done for me. I usually use multi-purpose grease on them, but I've read to use a moly based grease. Does it matter? I had one mechanic that also packed the back of the seal (where the spring is) with grease, but one of his seals failed in about 30,000mi. thanks
oil seals
I thought that putting grease into the back of the seal was suppose to help hold the spring in place when the seal was worked over the shaft. The grease was packed into the space around the spring
