Mine appears to have been sabotaged by a previous owner.
What SHOULD be there? is there some sort of grommet or similar that covers the big gaping hole?
I would gladly pay you tuesday for a hamburger today?manoa matt wrote:I should have one or two of the rubber grommets and the metal shields, but it will be a challenge to mount it to the surrounding chewed up sheet metal. It looks like the lower right screw holes is still there, maybe you can bend back or beat out the metal from the inside. Are you keeping the heater core? If not pull it and the tubes out and make a plate to cover the hole and paint it black.
That engine is looking sweet, great work! Just curious, what are the boxes on either side of the engine bay mounted to the inner fenders?
Nope! and HEY!boogiedude wrote:....are you running HIDs in an H4 housing?
