Painless Wiring Kit
- Your car is a: 1975 124 Sport Spider
Painless Wiring Kit
Hello all,
I was looking for what ever information I could find pertaining to others experience with replacing the wiring harness using Painless wiring kits. I found a couple related links including this one
http://www.fiatspider.com/f08/viewtopic ... ess#p24162
I was not able to access the pdf file that was mentioned. Seems it is no longer available at the link listed. I was hoping someone may have it available elsewhere?
Currently the harness is laid out threw out my car but nothing has been connected yet. I will document the process and post the process if there is interest.
Rob
Rob
1975 124 Sport Spider<br/>
1979 MGB<br/>
1981 Mazda RX-7<br/>
2002 Chevy Blazer<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- aj81spider
Re: Painless Wiring Kit
A.J.
2006 Corvette
2006 Corvette
Hey Rob, is your Spider fuel injected? I've had several requests from FI owners to update my article for their cars. Any additions or corrections to the article would be appreciated.
Thanks A.J and Bernie,
I've only had a chance to glance over it so far and I must say NICE job Bernie. Sadly no I do not have FI on my spider, it is an oversized single weber. I am however interested in converting to FI in the future. If / when I do I will be sure to document the necessary electrical changes.
Also I have selected a different Harness. I'm using the 14 circuit Micro Remote Mount Harness, P/N 10130. I selected this one because the fuse panel is considerably smaller than their standard unit. I liked the idea of it taking up less space under the dash. Sense it is a remote mount unit the wires are longer to accommodate placing it in the trunk. Looks like there would be more than enough wire to do this. However with the fuel tank, the fuel pump, and the battery there I thought I would mount the panel in the original location.
I was asked why do this. In my case a previous owner had hacked away at the original harness under the dash. I had straightened it out but over time the wire throughout the car had corroded and become brittle causing all sorts of problems. I didn't want further electrical issues, thus it is time.
Thanks again guys
Rob
Thanks again guys
Rob
1979 MGB<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- 124JOE
i also want to do a build.switching from a 32adfa to FI on a 78."smog removed"
i think i need rings and seals in the lower end.and case vent /vacume lines needes help
i reworked the timming and carb,undercoating,and some mild rust
and steering issues over the last few months.
and i have a FI from awile ago.and i found a puddle of oil while at an
idle but no leak if not running last month
sorry rrrrob,i didnt mean to steel anyones thread
just if we both need the same advise!
jump in
joe- janesville wi
jump in
joe- janesville wi
Hello, and thanks again for the help.
I've been studying the Following documents.
Painless Wire Harness Installation Instructions for 10102 & 10130,
Bradley Artigue's wiring diagrams for the 1969-1973 & 1977 FIAT 124 Spiders,
Bernie Seneway's Installation guide for the 10102 Harness rev. c,
Hayes Wiring diagram for the 1975 FIAT Spider
and I have some questions. On page 10 of Bernie's installation guide there is a chart pertaining to the FIAT ignition switch and the Painless harness. I see RED #934a & RED #934b listed under the Painless column, thing is Painless only lists a single RED #934. Am I to create a jumper which will connect both FIAT terminals to the Painless #934 circuit?
Rob
Rob
1979 MGB<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- 124JOE
that sounds right
You got it. I seem to remember two big red #934 on my harness, but no matter. Won't give any tech advise until rehydrated and rested 10.5 hrs. from Nashville. woof.
First a big thanks to Bernie, for all of his help.
I'm in the process of creating a wiring diagram that depicts the Painless 10130 harness in my 75 Spider, as I install it. So far I've found that the Painless 10130 harness is really close to the 10102 harness Bernie used in his documentation. SO much so that I'm using his article as a basis for the install. I hope to be able to share the diagram when I'm done. Currently it is neither accurate or complete.
Thing is I've run into some snags, I'm looking for help, and I don't want to lean completely on Bernie. It's not fair to him, just because he wrote the article, to be bothered by this. He's been a great help, I just don't feel right asking him for all of this help when I could be asking the forum.
A little background, I've owned this car for 30 years... can't believe that... It is the first car I purchased. Over that time much has changed, and I don't remember it all. The car has been sitting for some time and now I'm picking up the project again. More on all that later, elsewhere, etc.
Currently I'm getting tripped up on the Instruments and the Alternator.
My alternator is not original. I found this article
http://www.fiatspider.com/f08/viewtopic ... tor#p94799
my old alternator looks like the old black one in that article, the current one looks similar to the new one in that article but I don't believe mine has a built in regulator. I'd post an image but I haven't figured out how. I'd like to know what my alternator is. That is I'd like to know how big it is ?A, weather or not an external regulator is necessary and weather I should replace it with another. My guess is that I need an external regulator for this one. The original harness hasn't been in the car in a couple of years, and the regulator was in the car but I can't remember if it was hooked up.
so.. can someone post a link to "how to post an image" on this site.
Rob
Rob
1979 MGB<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- FiatMac
Here is a link on posting pictures.
http://fiatspider.com/f08/viewtopic.php ... os+#p48977
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
Thank You....
Does anyone know the specs of this alternator?
1979 MGB<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- Your car is a: 1981 Spider Turbo - missing the turbo
rrrrob wrote:Hello all,
Rob
ITA124 here on the forum has installed one in his Spider here in Australia PM him for details
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
2014 Abarth "SS"
Hello all,
looks like it is only 42-45 amp, externally regulated, so going to replace. Taking suggestion for new alternators, internally regulated, 2 wire, and higher amp rated.
Also looking for new headlight switch, would like to keep it as a toggle switch similar to the original. Haven't been able to fined a source. Lots of on-off-on switches to be had, but I haven't been able to find a nylon on-on-off or an off-on-on. Does anyone know of a source for these?
Rob
Rob
1979 MGB<br/>
2003 Mazda 6
1979 MGB<br/>
2003 Mazda 6
- Your car is a: 1979 spider
I'm using the same kit, just wondering if anyone knows what wires go to the alternator and where?
I have a '79 124 and the 55 amp alt. With an extra spade by regulator wires. Also, how to set up the dash light to indicate low charge?
Thank you kindly
Mike
Thank you kindly
Mike
