Anybody tried, Pertronix flame-thrower coil?
coise
Post by coise »
I just bought a pertronix MRLS1 ignitior system and I was wandering if a Flamethrower coil (60000 Volts 3ohms) would make a difference. I have presently a spider 1977 with blue bosch coil. What is the voltage and resistance of the bosch blue coil? I´m new to the forum so any help will be welcome.
chrisfiat
Your car is a: 1976 124
Re: Anybody tried, Pertronix flame-thrower coil?
Post by chrisfiat »
check the coil resistence closly, it must match the specs for the ignitor, my blue coil did not
manoa matt
Post by manoa matt »
Check the Summit website, they are one of the few vendors that list the primary and secondary voltage specifications for the coils.
coise
Post by coise »
Thanks for the advices. I checked on the summit web site but it doesn´t tell me anything about the blue coil. They sell it but that it... On the pertronix site they sau that you need at leat 1 ohm of primary resistance. What do you think? Should I get the flame trower 40 000Volts, it has a primary of 1.5 ohm. At least that what pertronix recommend.
baltobernie
Post by baltobernie »
I'm running the Bosch blue coil with the Pertronix module; works great. The distributor specialist who recurved my dizzy recommended this coil.
coise
Post by coise »
baltobernie, did you see any change with the pertronix ignitor? They say it increase the spark, but does it? I still would like to know the primary resistance and the voltage of the blue coil, can anybody give me this info?
Thanks again for all your input.
manoa matt
I have a new in the box Bosch blue coil at home I can measure and report back.
In the mean time this may help: http://www.ratwell.com/technical/BlueCoil.html
Adam
Post by Adam »
any issue running a bosch red coil with the crane xr3000 ignition? would I also benefit from moving to a pertronix or accel unit?
baltobernie
Interesting web site, Matt. He asks as many questions as he answers, however.
I bought my coil from Pegasus, and it is bright blue like the "good" ones shown in the link. Pegasus says that this coil is good for 6000 RPM, and my car makes no additional power beyond 5500. I don't have a comparison for Pertronix vs. points, as the dizzy upgrade was part of an engine rebuild. Nobody around here has one of the old Sun machines that displays spark waveform and amplitude on a CRT. Pertronix claims that their modules provide a precise spark duration depending on RPM, but I have no way of verifying this. My principal reason for converting was to maintain consistent ignition timing. The only other modification planned is a heat shield for the coil.
kmac33
Your car is a: 1974 Spider
Post by kmac33 »
I was running the Pertronix ignition module and the Flame Thrower 40K coil. Was very happy with the set up. Changed over to Mark's distributorless system to solve a hood clearance issue.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
coise
Post by coise »
Thanks Matt for the link. Sorry baltobernie about asking as many questions as I answers, I was thinking as I wrote.
Thanks again all off you for your input it´s always useful to me.
I think, I´m gone try the flame-thrower, the 40000 volts must make a differents somewhere..., and for 40$ it´s not so bad.
Daniel
Post by Daniel »
I have a brand new Accel for sale it's been sitting around for a while and i have no plans to use it
any more if your interested ? cost was $69 ill take $30 .
Daniel
coise
Post by coise »
Thanks Daniel for the deal, but I already ordered the falme-thrower coil.
Have a good one.
TulsaSpider
Your car is a: 1978 Spyder 124 2L
Post by TulsaSpider »
This topic is on points setup only correct?
coise
Post by coise »
yep.
Well, at least that what I have right now.
