removing intake manifold.
any advice for getting this thing off WITHOUT removing the whole stinking engine? I got one nut off but the one closest to the firewall is impossible to get at! Just trying to get rif of the old so when my new gets here I can run with it!
You may want to remove the crankcase breather oil seperator housing to give yourself more room. Taking the starter out will give you even more room -- but that is not a fun job, and is probably not necessary.
Whether you take the starter out or not, you ought to disconnect the battery, or else you may end up with sparks flying if your tools short out the hot wire from the battery to the starter!!
alvon
alvon
Re: removing intake manifold
Al, i took off the starter, and man did it help. I still have the one bottom bolt closest to the firewall to remove. Anyway, just thought I'd report that i did forget to disconnect the battery originally. BAD mistake. I'm sure you can guess the fuel and oil dripped around all in there. One little slip with the socket wrench and POP! and sparks! scared the bejeezez out of me, immediated thanked God that I still had my eyebrows and that there was no ignited fuel/oil/whatnot, and went back to D/C the battery. Just thought I'd throw that out there to any other newbies that think they can skip a 5 second step and leave that Bat connected!!!!!ventura ace wrote:You may want to remove the crankcase breather oil seperator housing to give yourself more room. Taking the starter out will give you even more room -- but that is not a fun job, and is probably not necessary.
alvon
SUCCESS!!!! (or should I say "suck-sess"). Let me just offer my 2cents to this manifold removal crap. It's not as stinking easy as it's made out to be. you CAN NOT remove the intake manifold by removing 2 screws on top and 4 scres on bottom. there are 5 screws on bottom. One is a shared screw with the rear timing belt cover.
Another cool piece of info. If you'd like to remove the manifold you need to deal with the tab from the rear timing belt cover because it will prevent you from pulling the manifold off. If you'd like to take that cover off, feel free. just keep in mind that you have to take out the tension bolt/spring thing. Not really something I wanted to do, so I did what any impulsive and impatient idiot would do. I got out my trusty dremel and hacked off that little tab. I don't see this ever being an issue except I might, at some time, develop an annoying rattle. Even with that little tab gone it was still pretty difficult to get that thing off because of the rear cover. I hope the 1800 doesn't have those clearance issues, cause I'm sure putting it on would be 10x harder.
so I can ditch the rear timing cover? How about the front cover?
I need to check my manual to see where this EGR valve is on the head, cause I don't see anything of the sort. BRB....
ok, Nevermind. Yeah, on the 79 and 80 carbed models that valve is right on the manifold, so I have already chucked it.
you can leave the front cover off if you want, just have to be careful while working on and running the car at the same time.
The egr valve is on the intake, but the passage from the exhaust goes thru the front of the head. If you have the stock exhaust manifold and don't plug the hole, expect a huge exhaust leak
You need to speak dumbese for me. This is new territory for me. Do you have a manual? I'm looking at page 10-128 and can't follow this stuff... I'll scan if it would help....So Cal Mark wrote:you can leave the front cover off if you want, just have to be careful while working on and running the car at the same time.
