...this shot shows the linkage for the steering. Ironically, the shaft from the original spider column works perfectly to connect the Camaro column to the ford Pinto Rack and Pinion. I cut the splined end off of the original column and welded it into the Shaft end of the Chevy column. The shaft on the camaro column is hollow and the solid FIAT shaft end fit inside perfectly with a little grinding.
I prepped the Lower control arm for a sway bar mounting that is similar to E Prod Racer's E production spider race car. I am using self-lubricating chromoly heim joints for the connection between the sway bar end and lower control arm. I just need to fab a mounting on the sway bar end.
Cheers!
Rob
