v6:
I built a rotisserie last year for a different project (a '68 Datsun Fairlady Roadster
), but I think the way I built it had some merit as far as some of the engineering goes. Something to consider:
If you're going to rotate the car, you'll want to be able to center the weight as close to the rotational axis as possible. That means either some serious math, or a level of adjust-ability. I chose the latter, and I'm currently enjoying that adjust-ability as I have a mustang on it now that required an extremely different setup!
I've scanned a sketch I just made to try to explain all of the different levels of adjust-ability.
Most of this adjustment came in the way of one pipe sliding inside (or outside) another, and bolting.
The critical areas of course were being able to adjust the height of the center of gravity, relative to the rotating axis.
For a bearing, I ran to the wrecking yard and picked-up a couple of front-wheel-drive hubs, complete with the wheel-studs so i could bolt-on the tube (but then I ended-up welding it anyway). I paid $10/ea. All scrap steel. Harbor freight had some cheap casters. I think I'm into the thing less than $100, including welding rod. (it aint pretty though....
My scanner's busted. I'll try to get it scanned-in... but here's a rough pic.
