Rob
That makes sense... The Rocker arms on a Chevy small block v8 have a ratio of 1.52:1. So the profile of that particular cam is not going to be as aggressive to get the lift your are seeking. Where as in the TC the ratio is stuck @ 1:1 therefore the cam profiles for high lift are going to be way more aggressive. Thus more wear and tear on the valve-train.guycroft wrote:No, it's nothing to do with the fact that the cam is direct acting ie: has rocker ratio of 1:1
A rocker valve train will develop valve lift in exactly the same way as a direct-acting one except that the cam lift is much lower and one relies on the mechanical advantage of the rocker mechanism. If the cam lift integral is hopeless so will be also the lift characteristic at the valve.
G
