Front brakes RESOLVED Need help with rear calipers RESOLVED
4uall
Re: Help with brakes, please
Post by 4uall »
GODDAMMIT! Now I will have to re-do them again! :evil: I'll order the new set then install. Thanks for the info :wink:
81SPIDERMATT
Post by 81SPIDERMATT »
that is just my preference... not set in stone..... i had a rattle that the bigger clips seem not to control and the little ones did
4uall
Re: Help with brakes, please RESOLVED?
Post by 4uall »
My brake pad springs arrived today. Did the front from start to finish slowly. The new springs seemed to have made all the difference and the fact that I no longer have two sets of different springs also helps. Went for a test drive and all seems well. Fingers crossed :shock:
Thanks to all
81SPIDERMATT
yeah...... that is good news.... love it when a plan comes together
4uall
Re: Help with brakes, please RESOLVED WHOO HOO
Post by 4uall »
Bought a torque wrench (must have lent mine out) put the bolts at 65 lb/ft and no noises ahhhhhhhhhhhhhhhhhhhhh yeeaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhh buddy :mrgreen:
4uall
Re: Help with brakes, please RESOLVED finally
Post by 4uall »
Daily driven and all seems well, going to try and tackle the rear brakes this weekend. Any do's & don't's you can suggest?
81SPIDERMATT
Re: Help with front brakes, please RESOLVED whoo hoo
if you are rebuilding the rear calipers pay very close attention to the wedges and how they come apart.... saves lots of questions at reassembly.... are you replacing any of the soft brake lines?.... in the back there are 3.... each wheel and a compensator in the middle..... also when bleeding the back brakes (if needed) you will have to have weight on the back axle for the compensator to flow fluid to the calipers..... and of course you know what clips to use ... lol
4uall
Post by 4uall »
:lol: clips :lol: I am hoping to just replace the rotors & pads as everything else looks/works fine I wanted all brakes done at the same time. Ebrake works great so not going to play with that for now.
81SPIDERMATT
rear calipers screw in to make room for the new pads and rotors.... cant compress them like the fronts.... some use a file.... sideways .... you will see what i mean when you get to that point.... i used (great tip from this site) a tire iron
4uall
Post by 4uall »
I went and purchased a tool for that exact procedure that I saw from a previous thread ($5.00) looking forward to using it and saving my hands etc :wink:
fiat218
Post by fiat218 »
4uall wrote:I went and purchased a tool for that exact procedure that I saw from a previous thread ($5.00) looking forward to using it and saving my hands etc :wink:
http://image.superstreetonline.com/f/95 ... piston.jpg
where did u purchase that tool from
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
4uall
Post by 4uall »
Canadian Tire however, State side you probably have them everywhere like AutoZone, NAPA, O'Reilly, Harbour Freight etc
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Post by RoyBatty »
Hey that tool looks familiar......
http://www.fiatspider.com/f08/viewtopic ... ol#p132866
:D :wink:
4uall
Post by 4uall »
I must be doing something wrong because this tool does not even move the piston :shock: :?
http://www.ehow.com/video_2327080_compress-caliper.html
Also tried a tire iron, wrench etc PLEASE HELP :cry:
81SPIDERMATT
Re: Front brakes RESOLVED Need help with rear calipers UNRESOLV
sorry you are having problems...one of mine was very hard to get started ... once started it moved ok.... the hard one i started with channel locks to get it going...as well as a clamp compressing a bit.... your going clockwise right?.... you have to push in while you turn.... i cracked the bleed screw open... dont know if it helped or not but seemed like it should help a little releasing pressure.... could be the piston is a little skewed to one side... try tapping on it with a hammer to let things loose and try the tool again
