Exhaust Fumes
Exhaust Fumes
Howdy,
While driving with the top down, there's a noticeable amount of exhaust fumes. Last May, I had the center and tail pipe replaced. I've always had some exhaust fumes, but it seems to be more now.
Is this just the nature of the convertible?
Clint
Clint
I'm sure you have done this, but just in case...
every joint at every pipe and each fitting for the catalytic converter and muffler all seal well. there is no leaks at any joint? There is no leak at any pipe seam?
You are sure that the exhaust manifold has zero cracks, and the fitting between the exhaust manifold and the downpipe seals properly?
The exhaust manifold is secure to the block?
Take it a step at a time, Clint. If there is a source (crack or hole or fitting separation) the cure is simple. We can continue the 'what if' game after we're sure about the exhaust system.
The British call that the 'boot'. Where do they come up with those names? And no, it does not make sense....but we read proof that even that is possible.
Someone go wake up Sherlock.....the game's afoot!
Howdy,
After visually inspecting the exhaust manifold down to the muffler, I don't see any cracks. Is there a test to check for leaks? Will a smog center be able to fine the leak or crack?
Also, I was told the fumes could be the result of the engine running rich. Is this accurate and what does running rich mean? How will it affect my engine performance? My Spider is an 82 with fuel injection.
Clint
Clint
Running rich is too much fuel mixture. Pull the plugs and see what they look like. IF they are black or carboned up, or if they smell strongly of gas, you're running rich. I imagine an FI system would probably be more sensitive to running rich, but the car would sputter and have black smoke coming from the tailpipe. Of course, I don't see how that would cause the problem of fumes in the cabin. Is your tailpipe straight or curved down toward the road? It seems I remember someone having a problem with fumes after replacing the tailpipe.
Howdy,
My tailpipe is straight out. The car doesn't sputter and runs well. I don't see any black smoke coming out.
People who have been passengers think the odor is more like gasoline than exhaust fumes. Perhaps, the gasoline odor is coming in from the engine. I noticed the ordor when I'm driving.
I can smell a small bit of gas odor in my trunk (is this normal?). So, I check the tank and gas line for leaks and moisture. I also followed the gas line into the interior of the car. Again, no moisture or leaks found.
So, I tried to check the plugs, but I can't remove the wire because they're pretty tight. Is there a special tool to remove the wires? I'm pulling at the end cap, not the wire itself.
Clint
Clint
Gee, FI is way out of my league...in fact, anything newer than 72 is . Maybe Mark will step in. Do the newer models have a vented fuel cap or the vent valve in the trunk? Could be a leaking injector seal or a seeping fuel line...don't they run on the inside of the car versus underneath? Hope you don't smoke!
