Clutch spring extension wire
FatherFiat
Post by FatherFiat »
I installed a new clutch in my '78 during the recent restoration. I have the external spring for the throwout arm, but have managed to lose the extension wire, which connected it to the tranny case. Does anyone out there know how long that wire should be? I am currently depending only on the pedal spring to keep the clutch arm where it should be.
Forgetful Fatherfiat
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: Clutch spring extension wire
Post by wachuko »
This one?
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
If that is the one, here you go:
Now watch me loose mine... :lol: Better put it back before I do...
Drive Safe!
Wachuko
2015 FIAT Abarth
mbouse
Post by mbouse »
that particular 'c' clip is made from unobtainium
wachuko
Contact:
Post by wachuko »
mbouse wrote:that particular 'c' clip is made from unobtainium
I will sell mine for.... 1 billion dollars!! :mrgreen:
Drive Safe!
Wachuko
2015 FIAT Abarth
mbouse
Post by mbouse »
will you take a check?
MNspiderman
Post by MNspiderman »
I believe if you unfold a paper clip it will be the same size, but i probably would double it up for strength :mrgreen:
wachuko
Contact:
Post by wachuko »
mbouse wrote:will you take a check?
I am very careful with accepting checks... I only accept checks from a nigerian bank.
Drive Safe!
Wachuko
2015 FIAT Abarth
mbouse
Post by mbouse »
how about cash ??
wachuko
Contact:
Post by wachuko »
mbouse wrote:how about cash ??
Of course, legal tender is also accepted.
Now, back to the main topic...
FatherFiat, was that what you were looking for??
Drive Safe!
Wachuko
2015 FIAT Abarth
manoa matt
Post by manoa matt »
"unobtainium" No such thing. I've got 2 or 3 of them, the spring too. matt.scarton@gmail.com
FatherFiat
Thanks for the reply(s) guys. But if you lose or break yours, just get a length of piano wire, about 1mm in diameter, and bend your own. A little heat won't hurt when bending, but quench it afterwards to avoid softening the steel.
8)
mbouse
Post by mbouse »
only a mm ?? wow, that's kinda narrow, 'eh?
