low oil presure reading
Mark_vaughn
Post by Mark_vaughn »
I have an ohm meter. What reading should I have? Or am I just looking for a change, if so what range?
I couldn't find any specs on low, mid, and high readings, so I'd suggest testing the sender resistance with engine off, idling and higher rpm and compare readings. I'll try and come up with some numbers for you.
Mark_vaughn
Thanks Mark.
with the ignition off, resistance from the sending unit to ground should be 280 to 300 ohms
with the engine idling, resistance from the sending unit to ground should be 150 to 180 ohms
if your sending unit is within range, you'll have to replace the gauge
Mark_vaughn
I don't know what I did, but after I tested it and messed with it for a while, it registered pressure again. Probably needs to be replaced, but it will work for now.
if you removed the sender, perhaps it had some debris in it, preventing oil from getting into it
