for me!
The first one is my 82 X19. I've noticed lately that it hadn't been starting
as soon as I turn the key and it finally decided not to start at all. I found
fuel puddling on top of the fuel pump and replaced the tranny cooler hose the
PO has used with a fuel injection hose. I also reinstalled the green/black
wire that had come loose from the fuel pump. When I turn the key on, it runs
continuously and I still get a puddle of fuel on top the fuel pump. I'll
recheck the hose and clamps, but is there anything about the pump that could
cause fuel to accumulate on top of it? How long is the pump supposed to run
when the key is turned on but the engine is not started?
My second one is my 71 Spider. I had noticed before parking it a couple months
ago that it was hiccupping and not running perfectly smooth like I know dual
IDFs should...anyway, I got in it today to start it and after the customary
engage starter for 5 seconds, pump acc pedal 10 times, repeat at least 7 times
or more if necessary....my car would not start. I looked at the clear fuel
filter and can't see any gas in it. Are my assumptions correct that my
mechanical fuel pump is toast? Is there a way to check it without pulling it
out of the car? Tell me again why I love my Fiats?....okay, I drove my 72 for
3 hours today on beautiful twisties so you need not answer that.
