No injector pulse on FI
- Your car is a: 1982 Pininfarina Spider
I have refurbished this FI prior and own almost a whole 2nd set for testing including an ecu. I recently rebuilt the motor and I’m reinstalling the fuel injection. The dual relays are operating, the ECU pin out checks out for positive and ground. I’ve got 12 V positive at the injectors, but no negative closing of the injection from the ECU. I have the J Tronic diagnostic manual. I’ve checked all the contacts for the relays and the ECU panel. The manual says to replace the ECU. I installed my other working ECU. But still no injector pulse. What can I check to verify, the computer is operating? I doubt both of my working issues have suddenly stopped working. What should I be missing here?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Re: No injector pulse on FI
You didn't mention checking for the ignition control pulse (ground) on pin 1 of the ECU. Do you have spark at the spark plugs? Does the Yellow wire on the D (-) terminal of the coil trace to pin 1 of the ECU. The ECU needs a momentary ground from the ignition control module to trigger its injector circuit.
That was it. I had it as coil + in my notes. Thanks
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Great. Thanks for your response, all to often folks don't replay once their car is fixed so one never knows if the issue is resolved.
