Acorn Nut on Brake Booster
SteinOnkel
Post by SteinOnkel »
Hello,
is the spec for the acorn nut adjustment measured from the base of the booster or the top of the plastic cup?
Steiny
tima01864
Patron 2021
Patron 2021
Re: Acorn Nut on Brake Booster
Post by tima01864 »
Base of the booster.
SteinOnkel
Thanks, I saw that. The picture is grainier than the cereal I had for breakfast though.
I tried that, couldn't get it to bleed because literally nothing was pumping. Then I screwed it out two turns farther, bled fine, braked fine UNTIL the sucker got a little hot, then it started dragging :-/ So I'm thinking one turn in and we're good. It's not rocket science.
