Grounds
BS9ider
Your car is a: 1978 Spider
Grounds
Post by BS9ider »
Hi, I fitted a new battery to a project car I've recently acquired. I had no ignition lights so I cleaned the ground in the trunk and got ignition lights. However when I turned the key to start all the lights went out. I've orderd a Haynes manual but until that arrives I'd appreciate advice on other areas to check. Assume theres more grounds to clean ? Many thanks.
MattVAS
Your car is a: 1976 Fiat Spider 124
Re: Grounds
Post by MattVAS »
There are a couple grounds in the engine bay and under the dash.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Stock parts or Performance parts we've got what you need.
BS9ider
Re: Grounds
Post by BS9ider »
Thanks Matt, will check those too
Odoyle
Re: Grounds
Post by Odoyle »
There should be a ground on the passenger side engine bay on one of the the studs which mounts the coolant res. And hugely important to make sure the ground strap (in engine bay to lower left of steering box) is tightly attached to transmission bellhousing or similar spots. I found that the bolt hole on the bellhousing in my 77 was stripped, preventing proper connection. Also, check near or underneath the dash for an dodgy looking grounds. I have found a double black wire ground terminal screwed into the bottom of the foam dashboard (not a great spot). My solution, under the dash, was to install a grounding pod like I found in my 79 & 83. Image
BS9ider
Re: Grounds
Post by BS9ider »
Thanks Odoyle, cleaned the pods in the engine bay but still same issue. Just checked coolant res and i have some suspect wires and some kind of plastic connection, will post a pic. Appreciate any feedback.
BS9ider
Re: Grounds
Post by BS9ider »
Sorry, silly question. How do I post a pic?
BS9ider
Re: Grounds
Post by BS9ider »
Just checked the Battery connections again and the + lead connector and first couple of inches of cable are warm even though ignition is off? Still no ignition lights so I've disconnected for now.
BS9ider
Re: Grounds
Post by BS9ider »
Applied some copper grease to the battery terminals and ground. I've now got ignition and the car turns over! :D
BS9ider
Re: Grounds
Post by BS9ider »
