Rear Fiat 500 brake kit install
Anybody know the diameter of rear disc for my 83?
- engineerted
Re: Rear disc
It is the same as the front. 227mm, all 124's use the same disk front and rear, except the 85.5 model year spider.
Ted
Re: Rear disc
Ok thanks! I will use the Fiat 500 disc to fit the rear caliper from Fiat 500. Just need to do the bracket to hold everything.
- Your car is a: 1984 Pinninfarina
Re: Rear disc
Let us know how it works out.
In the video below looks like he was going to re-clock the emergency brake mechanism.
See the link for the video below.
https://youtu.be/6FRJGW3yX44
Re: Rear disc
Not that problem because the caliper will be install in the back. I will try to use the original parking brake but will see.In the video below looks like he was going to re-clock the emergency brake mechanism.
Re: Rear disc
First modification is removing 1/10 inches to enlarge center hole of the rotor.
Re: Rear disc
Plates for mounting the caliper at the rear are done. Laser cut in 1'' steel. Now my plan is to pass the brake line in the front of the diff so i will be able to connect my hose from the back.
This prototype was made of steel but the guy plan to built them from anodized aluminium 1'' thick for around $120 US including shipping.
Re: Rear disc
Adaptors made for the brake line 1/8'' steel.
Ready to install the brake line.
