Any reason why fiat did not see fit to place a fusible link on such a long battery/starter cable?
Has anyone fitted a manual reset breaker to their starter/battery cable link? Double duty Safety/Disconnect.
All views welcome
I am pretty sure there is a high short duration surge current associated with a solenoid that exceeds its operating current. Fusing this type of circuit is often done with slow-blow fuses.Starter solenoid current (peak value) 17,5A.
So if you want to put a fuse there 25 A is fine (as Bosch recomends)
Current will stay at 17,5 A as long as solenoid is pulled.
