thing above the gas pedal leaking on my carpet on 82 FI
- Your car is a: 1982 Pininfarina Spider
I cant seem to identify this small boxish device above the accelorator pedal. It has a wire mouse on it. It is leaking somesort of oil on to my carpet. Please help.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
- 124JOE
Re: thing above the gas pedal leaking on my carpet on 82 FI
can you post a picture of it?
That is likely the reset box for the catalytic converter warning light, and has no fluid in it. Possibly there is a coolant leak from the heater box and it is presenting itself there?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
That is the counter that illuminates the light to replace the oxygen sensor every 30k miles. You may remove it an throw it away, but be sure it's notsomething above it leaking onto it, like a rust hole in the cowl area letting water in.
I figured it out. My old brake resevior leaked onto the wiring harness and the harness runs on top of the counter. You say i can remove the counter? any issues with doing that?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
- Your car is a: 1985 pininfarina spider
some states and the feds have laws about removing anti-pollution related devices. might want to check your local and federal laws on this.
I don't even need to do emissions. Im only concerned about mileage and performance
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
