master cylinder front brake no fluid
veloce
Post by veloce »
installed new rear calipers,installed new front calipers bled rear everything fine good pressure,trying to bleed front no pressure to calipers,disconnected line at master no fluid come out, PLEASE HELP NEED TO TAKE THIS CAR ON ROAD IT IS TIME AFTER THIS BAD WINTER.
THANK YOU
divace73
Re: master cylinder front brake no fluid
Post by divace73 »
you may need a new master cylinder as well???
Check the hose from the reservoir to the MC is not blocked....
Cheers David
see my >>You tube channel<<
veloce
Post by veloce »
master cylinder hose new
veloce
Post by veloce »
five months ago ichanged power booster could be that i did not set the rod lent where was suppose to be?
DieselSpider
Post by DieselSpider »
veloce wrote:five months ago ichanged power booster could be that i did not set the rod lent where was suppose to be?
Try gravity bleeding them. If the flex hoses to the front calipers have not collapsed they should gravity bleed easily. My 78 Spider is the only car I have owned that actually gravity bleeds quite well with no need to leave the bleeders open for hours to get the flow going. Else you may need to vacuum bleed them to prime the master cylinder.
