Can someone tell me how to remove this piece of bright trim without destroying the door paint or the trim piece itself?
Looking for advice from someone who has actually done this themselves.
Many thanks:
How does this trim come off?
- focodave
1970 MGB GT (my other hobby)
- Patron 2019
Re: How does this trim come off?
It just pulls up.
I used an ice pick under the edge by the door jamb to get it started, work your way along. A rag underneath and a gentle use of a screwdriver can help prevent bending it as you work it up along its lenght.
A little more detail in this thread http://www.fiatspider.com/f08/viewtopic ... 30&t=30081
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
- divace73
My One comes off buy lifting it straight up, I use this plastic trim up removal tools, may also wedge a thin plastic sheet (like cut out of an ice cream container??) to further protect the paint work under the tool??
Cheers David
see my >>You tube channel<<
- focodave
Thanks very much for your prompt responses, guys.
Very helpful....
Very helpful....
- 81SPIDERMATT
mine comes off when you roll up the window .... i would love to know if there is some type of clip that i am missing or do i just need to pinch it a bit so it stays on better .... Matt
Mine also goes up when i close the door.i nave also some clips that hang it,but it isn't enough. Someone have an idea to tell me how can i do to stop it?
I used thin self-stick foam sheets (available at Michaels Crafts stores). Cut thin strips and stick these along the window gap edge. This gives the trim pieces more to bite onto.81SPIDERMATT wrote:mine comes off when you roll up the window .... i would love to know if there is some type of clip that i am missing or do i just need to pinch it a bit so it stays on better .... Matt
I think you need that:
http://www.vickauto.com/newstore/index. ... ts_id=2457
or
http://www.autoricambi.us/product/RE7-4 ... -Retainer/
Hope that helps.
or
Hope that helps.
Thank you very much to all of you...i think that your advices will be very helpful!thank you you are great...
