Driveshaft removal 1983 124
Odoyle
Post by Odoyle »
So my driveshaft repair kit got in today and I'm about to begin disassembling the driveshaft and was curious where I should start from. Any particular tips or techniques on how to disassemble the driveshaft?
azruss
Re: Driveshaft removal 1983 124
Post by azruss »
If you are not replacing the guibo, then i would start from the rear axle and disconnect it. Then unbolt the pillow block and pull the splines out of the front. When you disassemble the 2 pieces, mark the orientation of both pieces so they go back together the same way.
Odoyle
Post by Odoyle »
I'm replacing the guibo, both u-joints, and the center bearing. Should I begin disassembly by disconnecting the end of the driveshaft closest to the rear axel first? Or should start near the guibo, behind the tranny?
124JOE
Post by 124JOE »
at the rear end
4uall
Post by 4uall »
ClarkTheShark
Post by ClarkTheShark »
It doesn't matter where you start. BUT BE SURE AND MARK IT. IT WILL COME APART IN THREE PIECES. MARK ALL THREE.
Ask me what happens when you don't mark them...
