Help with LED Clock Removal
lglade
Post by lglade »
I'm hoping I can get some help here on removing the Borletti LED clock from my 1984. I'm trying to remove the upper and lower consoles to install a new heater core and valve, and as I understand it, the last screw is hidden behind the clock. I've removed the other screws (or so I think) but I'm struggling with the clock and I don't want to destroy the faux wood panel that surrounds the clock. Has anyone does this? Any tips or tricks?
Thank you all.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
bradartigue
Re: Help with LED Clock Removal
Post by bradartigue »
It has been a long time since I worked on a pininfarina interior but if I recall you can use a plastic screwdriver (or thin plastic something) between the clock and wood and pop it out, it has tabs on either side that hold it in.
