'79 Spyder Interior Mirror
- Your car is a: 1979 Spider
Looking for a clear interior mirror for my '79 Spyder. thanks very much.
- spidernut
Re: '79 Spyder Interior Mirror
Are you missing the mirror or is it just foggy? The mirror can be disassembled and cleaned. The outer ring is just pressed in place and comes of quite easily. You can then clean everything or even replace the mirror and or glass if you want and reinstall. It is an easy repair and cheap.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Thanks very much, spider nut. The mirror's just foggy, so I'll try to take it apart & clean it.
not quite so simple. The day/night tab just pushed a flexible piece of plastic that is often old, brittle, and on the brink of failure. The mirror is also very thin (1/16"). The thinnest mirror i can find is 1/8" and that is too fat to work. I have 4 old mirrors and ended up buying a new one.
I took it apart tonight, cleaned it up....remounted it....so far, so good! Thanks again.
Onlinebtoran
- Your car is a: 1975 Fiat 124 Sport Spider
my interior mirror won't stay in position and the tab that switches from day/night mode isn't working. i took the mirror apart and the tab inside is broken. also, there are interior pieces/spacers missing. is there any fix for this other than getting a new mirror?
1975 Fiat 124 Spider
- spidernut
Silicone glue might work. The day/night mirror tab is very poorly designed. You might have to just use a little silicone to hold it all in place.
John G.
