This just seems strange to me but when I pump the brake, my engine RPM goes from about 1000 up to 1500 +. If I just hold the brake down, the RPM stay steady at around 1000. The RMPs only increase when I pump the brake repeatedly and the faster I pump, the faster the engine speed goes.
I discovered this after doing a little brake work and needed to get the caliper pistons back in place after pushing them in with a clamp.
RPM increases when pumping the brake
Re: RPM increases when pumping the brake
you're moving a large amount of air when you repeatedly pump the brake pedal
Pinch the vacuum line to the booster and see if problem goes away
... or sell this performance-enhancement to Mike for those Michigan Lefts.
if holding the pedal down steady doesn't increase rpm, then the booster is okay
What air is moving by pumping the brake pedal? And does this mean that when everyone else pumps their brake pedal their RPMs increase?So Cal Mark wrote:you're moving a large amount of air when you repeatedly pump the brake pedal
Mine does. That's how I kept it running at stoplights when I had a Holley carb on it.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
