Silly question but I just want to make sure...
The line that goes from the fuel tank -> fuel pump should go to the fuel pressure regulator right? I just wanted to ensure that I didn't hookup the supply / return fuel lines backwards after my restore. Trying to determine why the '81 won't start after my interior rebuild.
'81 won't restart and FI fuel lines
- rjkoop
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Re: '81 won't restart and FI fuel lines
Fuel line on mine goes directly to the fuel rail. The line on the bottom of the reg goes back to the tank.
- rjkoop
That would explain why the car doesn't start! I think I hooked it up backwards.narfire wrote:Fuel line on mine goes directly to the fuel rail. The line on the bottom of the reg goes back to the tank.
I wish I looked at this picture before...
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
It's amazing how easy the car starts when I hookup the fuels lines the RIGHT way!
http://www.youtube.com/watch?v=tE0aKvxS ... e=youtu.be
The temp went up to about 200, radiator hoses were hot and fan came on!
http://www.youtube.com/watch?v=J6zMJzFv ... e=youtu.be
Unfortunately I noticed some smoke from the exhaust/cam cover (hard to tell).
http://www.youtube.com/watch?v=BUK8J-i0 ... e=youtu.be
I did spill some coolant on the exhaust manifold but I think there might be a leak in the exhaust/cam gasket. I think maybe the SeaFoam I put in the gas may have exposed a weak point because when I 1st got the car I didn't noticed the leak.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
