Blinker kit from mark
fiat218
Post by fiat218 »
Where do most people mount this lights, I'm bumper less
81SPIDERMATT
Re: Blinker kit from mark
Post by 81SPIDERMATT »
i used the oval holes.... they need to be "wallered out" a bit
fiat218
Post by fiat218 »
81SPIDERMATT wrote:i used the oval holes.... they need to be "wallered out" a bit
Ok great, so they need to be a bit bigger
81SPIDERMATT
you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
fiat218
Post by fiat218 »
81SPIDERMATT wrote:you just have to round them out a bit...the holes as is are wide enough just not tall enough if you know what i mean.. do a little at a time and then check fitment .... i would wait until you have the kit in hand..... dont just round them out
Thanks, i have them. I just have not looked at them yet. I seems to loose stuff in my garage.
What did you use to cut it out
81SPIDERMATT
i used some type of grinding thing that fit in my drill... looked like a small barrel .... the guy at ace said it would work... not a whole lot needs to be removed.... did not trust my abilities with my big grinder tryiing to finesse a cut in that small space.... worried that i would cut too much or catch and run a big scratch.... and the sawzall seem to be overkill
fiat218
Post by fiat218 »
i seen that not much needs to be removed
how did u fasten that light? what did you use on the back side?
the light has a cup that mounts from the back side to secure the light
fiat218
Post by fiat218 »
So Cal Mark wrote:the light has a cup that mounts from the back side to secure the light
Ok I was thinking that's how it would go, but was not positive, thanks
And I got to buy my own nuts? Lol
fiat218
Post by fiat218 »
Hooked up. But not in place yetImage
fiat218
Post by fiat218 »
SLOSpider
Post by SLOSpider »
Don't JACK UP that light install :D
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
with a Dremel or similar grinder, remove a slight amount of metal from the top and bottom of each bumper shock hole. The rubber grommet will fill the gaps around the edges of the lights.
toplessexpat
Post by toplessexpat »
While there's nothing wrong with the blinker light kit ... ;) ... I elected to fit some custom truck headlamps with integrated LED blinkers in the the bottom 10mm or so. There's also a row of LEDs for the park lights.
Ping me if you'd like pictures - on the Texas Hill Country run a couple of weeks back, people saw mine and weren't overly critical :D
Andy
www.mirafiori.com
SLOSpider
Post by SLOSpider »
Post up some pics topless
1975 124 Spider
