replacing distributor seal, is timing necessary?
I'm going to be replacing the seal on my distributor. Is it necessary to do the timing after replacing the seal? Thanks
Re: replacing distributor seal, is timing necessary?
only if you want it to start and run properly
well I guess that answers that. shows you how much I know about the mechanics of the car, but I sure do have a lot fun driving it! thanksSo Cal Mark wrote:only if you want it to start and run properly
- Your car is a: 1975 Spider
the easiest way to do what you want is to get the motor to top dead center before removing the distributor. line all of the timing marks up then remove the distributor. but if you have never replaced a distributor seal in a fiat. be aware. it has its own challenges. The pin can only be removed in one direction, it will be very hard to remove. there have been a few distributors in my life where i could not get the pin out. I have made a special tool that i use in my air chisel to remove pins.
Good luck. All of this being said yours might come out real easy. Remember top dead center on a fiat is firing to cylinder #4
son has 78 spider
son has 78 spider
I need all the help I can get...thanks for the replies guys!
