So, what I'm thinking is that I'll build a flap out of the aluminum panel that covers the original speaker and put the radio in the area under where the old radio is. I've got some sheet steel that I plan on using to back the aluminum plate so it's less likely to bend. I went out to the parts car tonight and pilfered the radio stack interior piece and started thinking about how to build everything. I thought about an old garage door type panel where it would fold up an into the cubby hole but I think it would hit the radio.
The picture below shows the current route I'm considering where the door would just flip down on a hinge at the bottom and lay in front of the shifter. Based on my quick test 5 minutes ago it doesn't seem like it will interfere with the shifter. I'll be working on this over the next little bit and will keep you updated as to how it goes. Wish me luck! Oh, and if someone has done this already please point me in that direction.
