1980 2000
fiat218
1980 2000
Post by fiat218 »
can a person buy this rubber piece that slide down the window /door top.just behind the chrome on the top of the door
thanks
Re: 1980 2000
I think Auto Ricambi (Csaba) has those pieces.
fiat218
Re: 1980 2000
Post by fiat218 »
i just emailed him to see, thanks
Door Glass Vertical Channel Felt <<< is that what it is called
Re: 1980 2000
I bought the window slider felt from them and it fit fine. Comes a little long and you can trim it to length with aircraft snips. Attaching it to the upper door panel piece is another challenge. I used split rivets, I think it takes 4 or 5, can't remember exactly. I set them by first spreading the tangs slightly and then setting the final set with a bigass vice grip. There is very little room to get into the channel with any tooling. This is probably confusing but it will be obvious what I am talking about when you get the door panel disassembled. It is very doable.
fiat218
Re: 1980 2000
Post by fiat218 »
I will check that out, I don't got felt on this one
Re: 1980 2000
I may be confused... wouldn't be the first time! From your pic it looks like the piece that goes against the window on the inside? That has the felt, mine was so worn that it didn't look like there was any there. The outside rubber one I have not changed, so I cannot comment on that one.
fiat218
Re: 1980 2000
Post by fiat218 »
yes that what it is, but i don't see felt on mine, just the rubber
fiat218
Re: 1980 2000
Post by fiat218 »
RRoller123 wrote:I may be confused... wouldn't be the first time! From your pic it looks like the piece that goes against the window on the inside? That has the felt, mine was so worn that it didn't look like there was any there. The outside rubber one I have not changed, so I cannot comment on that one.
oops, this rubber is on the outside not inside
is there suppose to be felt on the inside too
Re: 1980 2000
No felt on the outside, just rubber. The inside has the felt! But I think Auto Ricambi carries both pieces. Sorry for any confusion I may have caused.
Pete
fiat218
Re: 1980 2000
Post by fiat218 »
it fine, i know the rubber on the outter is bad and asked about that, he showed me the inner which is felt, i will have to look and see if mine is ok on that part
no confuse here, thanks
Re: 1980 2000
Just my 2 cents, when the door panel comes off for any reason, it would be great to put the new felt on. I was amazed at the improvement in the looks of the door, makes it look brand new! Such a small thing and such a large effect.
Pete
fiat218
Re: 1980 2000
Post by fiat218 »
RRoller123 wrote:Just my 2 cents, when the door panel comes off for any reason, it would be great to put the new felt on. I was amazed at the improvement in the looks of the door, makes it look brand new! Such a small thing and such a large effect.
Pete
door panels are off. getting re done
good idea then, thanks , i see there are rivet to it, so how does a person do this ?
baltobernie
Re: 1980 2000
Post by baltobernie »
Drill out the rivets. As Pete states, new felt makes a big difference; you can drive on chilly days with the windows up without rattles.
Re: 1980 2000
I bought "split rivets" from Ace Hardware up the street, set them by initially slightly spreading the tangs with a flat screwdriver while holding them in tight, then fully setting them flush with a large vice grip set to really put the pressure on. It worked fine. I couldn't find or see a way to get any kind of tooling into the foldover where the rivets are
Re: 1980 2000
If I remember correctly, the split rivet head went on the felt side and was buried in the felt so it is not visible after the split rivets were set, and I think there were 5 of them.
