what carb is this
Re: what carb is this
that yours?
Jim,
If you put a 1800 manifold on your 79 you will need to make a bracket for the oil dipstick since the 1800 manifold is smaller externally and the dip stick will have no place to bolt to.
You can always get a FI dipstick and fi dipstick cambox bracket.
1980. not 79
they the same?
nothing can just be easy huh
they the same?
redek wrote:It might be a little bit more to buy it from mark, but if you have any questions about the install he will help you figure it out.
that means alot some of people. that great that he helps
thanks
- manoa matt
Send me the extra $70, I'll give you a linkage lever and tell you how to hook it up.
excuse me ? extra 70 for what
i want to replace the carb as u seen in the photo, what should i use. i do that a 1800 manifold
and what of all this smog? what do i do with that.
- Your car is a: 1979 and 1980 spider
I have a 79 and did this conversion. I removed all the pollution parts. I run a 1600 plaine manifold. I plugged all the holes on the manifolds leaving open only the vacuum for the breakbuster and distributor. It starts at the first kick after the installation. You will need some small modification on the original carb link. I did not have a chance to drive the car because of drive shaft/rust issue so I do not know how the performance will be.
does a person need the vacum advance on the dissy if u switched carbs?
- 124JOE
yes the dizzy still need it
I purchased my EMPI 32/36 at http://www.appletreeauto.com. At the time it was $215.29 with another 10% off and free shipping. I ended up buying a new spacer and some extra gaskets and had it shipped to my door for right at $203.00 and some change. I don't believe the 10% off deal is still going, but you can still get the carb for $215.29 with free shipping plus whatever gasket(s) you need. I bolted mine on to my '73 with a 1600 and it works like a charm. I fought a 34/34 Weber Interco for several weeks, and can't believe how much nicer the EMPI works.
