Brake Booster
FMO
Brake Booster
Post by FMO »
I have bought a new brakebooster and installed it. It works just fine, the car is braking good +++. The only problem is when I brake a bit harder then normal, the revs at the engine is getting higher??????
When I drive and press the clutch down + press hard at the brakes, my engine`s revs is raising high, when I disengage the brake pedal, it become normal again? Can someone answer me why this is happening? :?
Best regards
FMO
FMO
Post by FMO »
Hi!
Finally I found what the problem about the high rpm when braking was. An another Fiat club member in Norway have had the same problem with his Fiat Dino Spider. The problem was very easy to solve.
My trottle cable was to tight, since the engine was moving forward ( a little bit) when I was braking hard, it also moved the throttle cable, and then the rpm was increasing lol. The only thing I had to do, was to easy the throttle cable up a bit, and voila everything was ok
regards
Fred Michel
kmartin83
Post by kmartin83 »
The perfect fix -- easy and little to no cost!
mdrburchette
Post by mdrburchette »
Glad you figured it out. That one was a bit perplexing.
sounds like the firewall is flexing, maybe a crack or two?
FMO
Post by FMO »
Hi!
No there is no crack in the firewall. But when I have choose to setup my throttle linkage like I have, and the wire is too tight, the wire will move when the engine is moving forward a bit ( when I brake). :?
http://home.online.no/~ellholt/fiat124s ... pDispType=
regards
FMO
I just can't imagine the engine moving every time you brake :(
FMO
Post by FMO »
Hi again!
Neither could I :? But the rpm didnt raised when I braked normally, only when I brake heavier. And when the throttle wire was so tight, I can imagine ( now ) that the movement of the engine could cause the problem I had.
manoa matt
Post by manoa matt »
Maybe time for some new engine and trans rubber mounts.
matt
FMO
Post by FMO »
All the rubber mounts are years old :wink:
FMO
Post by FMO »
3 years old ---he he, forgot ta push my num lock on
