Workin' under hood
mostlytwowheeled
Workin' under hood
Post by mostlytwowheeled »
Well the sun broke out yesterday and temp was in the 40's. So I took off the tarp covering "Tony" and put on a new fuel pump. Next will be the intake manifold and carb. But before I get to that I need the small molded ruber tube from the block to the vapor/oil seperator casting. Anyone know where I can find one? I checked the IAP catalogue, but couldn't find one there. Thanks
Re: Workin' under hood
there are two different hoses, depending what year engine you have
mostlytwowheeled
Hi Mark, That engine would be a 79' 2 liter. Might you have one?
mostlytwowheeled
Found one. It's on it's way.
jaownbey
Post by jaownbey »
mostlytwowheeled wrote:Well the sun broke out yesterday and temp was in the 40's. So I took off the tarp covering "Tony"
40's?! You need to move south my man...
