Oil type/viscosity 81 Spider
loc8tor
Post by loc8tor »
I have searched and searched and still am not 100% sure what I should use in the fiance's Spider. I have read that 15w40, or 10w30, or Mobil 1 5w40 is what to use. I dont want to start another thread about oil on here, just a simple answer as to what to use in this engine. Thanks
rlux4
Patron 2022
Patron 2022
Re: Oil type/viscosity 81 Spider
Post by rlux4 »
I'd bet that Shell Rotella 15W/40 is the most used oil by members here, me included. Available just about everywhere, even Walmart.
Ron Luxmore
rlux2n2@gmail.com
my heart sagged a bit when I saw the title :cry: , but I'll second the 15-40 Rotella or Castrol Syntec
brunorahl
Post by brunorahl »
I'd run 20w50. The Fiat tolerances are quite loose. Synthetic would be a great idea on a fresh motor, but it tends to leak on older motor. The seals don't seem to like it once they have had conventional oil for years and years.
engineerted
Your car is a: 1974 124 spider
Post by engineerted »
The correct answer is, it depends on where you live and what type of driving you do.
3 votes 15-40 rotella
20w50 if you live in the hot southwest
Ted
Ted
Mathew26
Post by Mathew26 »
20w50 springs and summers with 10w40 for falls and winters has never gone wrong for me.
loc8tor
Post by loc8tor »
Thanks for the input....I decided on running the 15w40 Motorcraft(since I work for Ford) synthetic blend. With a can of BG MOA for some added Zinc. It does seem to carry more oil pressure with this oil. Maybe next oil change I will try the 10w40 and just see which the engine likes better. I did notice a small oil spot under the car will check it for leaks next time I drive it to work. THANKS!
