compression 2000 ie
stephanspider2000
compression 2000 ie
Post by stephanspider2000 »
what should the compression be for a 2 liter fuel injection spider.
i measured 8.5 bar (about 125 psi) on all the cinlinders
is that ok?
beachboy
Re: compression 2000 ie
Post by beachboy »
Thats fine, what is more important is that the cylinders are close in number to each other. One different number away from the other three means potential trouble.
stephanspider2000
every cilinder is the same, so i guess everything is ok there
when my spider is warm he is idling speed is going up and down a bit
anyone know what can be the problem?
can it be the airmeter?
I followed the manual on artique's site and the values on didn't match up with his
the value on pin 7-8 was 300 ohm instead of the manual's 1200 ohm?!?
the car is running very fine ,it's just the idle speed
stephanspider2000
