Brought it home today - pics!
okartguy
Post by okartguy »
This is my freebie '80 in as-found condition (stored outside, under a cover since early '02). Figured I'd document it before I get to work cleaning it up... lovely, huh?
I haven't started it yet; after surveying the damage to the oil pan, I'd rather get the pan and pump replaced first. Other than that, it's completely solid, with zero rust even behind the front seats.
mbouse
Post by mbouse »
cool.
and you are on your way!!
don't forget to check those brakes after you get that oil pan & pump fixed. it is a real pain to find out after you are at crusin' speed that you need to, but cannot stop.
mdrburchette
Post by mdrburchette »
Wow, not bad for the price. :D
spidernut
Post by spidernut »
You may want to check the manufacturing date on the door jam to see what year it was built. If you have a 1980 model, it is probably late 1980 because you have fuel injection. Looks like a great start! The car looks to be in pretty good shape overall. Doesn't look like any significant bodywork is needed. That'll save you a ton of money!
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
all 80 Calif models were FI, federal models were carbed. Take a close look at all of the FI hoses under the hood before you attempt to start it. That system runs about 45lbs of fuel pressure, and even small leaks can create a huge fire.
good find though!
mbouse
Post by mbouse »
my 1980 is carburetted and it was manufactured 10/79
okartguy
Post by okartguy »
Date of manufacture for my car is 10/79 as well, so this must be a Cali car. I've got alot of experience working on older VWs (my '79 Westy is also a Cali FI model), so it's nice to see the familiar Bosch AFM and related componentry under the hood.
And yes, before I make any serious attempt to run the car, I'll be dropping and cleaning the tank, as well as replacing all of the rubber FI lines. Fiery Fiats are no fun at all.
the underhood tag on the cowl will tell you if it was mfgd for Calif or US specs. Sometimes the left door jamb will also have a tag, but I noticed in the pic that the underhood tag is intact
okartguy
Post by okartguy »
Well, I was just out poking around and also noticed a "California" tag on the front of the cam belt cover. So I guess that seals it!
topless moma
Post by topless moma »
:shock: What's the deal with that Hurst shifter?!
