Dropping gearbox
Dropping gearbox
Does anyone know of its possible to remove the gearbox from underneath the car, I have to replace my clutch fork and don’t want to pull the whole engine again.
- wachuko
- Contact:
Re: Dropping gearbox
Of course it is. And relatively easy to do. That is how I removed the gearbox from my parts car.swede wrote:Does anyone know of its possible to remove the gearbox from underneath the car, I have to replace my clutch fork and don’t want to pull the whole engine again.
Need to remove the shift boot and knob, unplug the reverse light connector, disconnect the drive shaft, remove starter, cover to the flywheel, etc... I had the use of a lift, so I just placed a table under the car and with the use of a transmission lift, lowered it down. But same can be done on jack stands.
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- red107
- Contact:
That is how I did it. Will be doing it again here soon.
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
Thaks guys,
I just wanted to be sure before starting this project
I guess it will be done later this week.
I need to be ready for the upcoming fiat event 1st of May, will upload some nice pics from the meeting.
Yeah very easywachuko wrote: Of course it is. And relatively easy to do. That is how I removed the gearbox from my parts car.
Was forced to take some rest before jumping on this again tomorrow, I need to have everything done by next week.
The Spider needs to be done so I can go to the annual Italian Car Meeting 1st of May.
- wachuko
- Contact:
I should have provided more details... it is fairly easy, just need to make sure you have the right tools from the get go...swede wrote:Yeah very easywachuko wrote: Of course it is. And relatively easy to do. That is how I removed the gearbox from my parts car.It´s still in place since I cant reach one of the top starter bolts.
The Spider needs to be done so I can go to the annual Italian Car Meeting 1st of May.![]()
As everyone suggested when I went to take down mine, you really need these..
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Thanks wachuko that was just the tools I used to get it off, finally.
The clutch fork is replaced and the gearbox back in place and all wires etc will be connected tomorrow.
Ones everything is back in place it will be a test drive around the neighborhood, just need to bleed the brake lines first.
I might just make it in time for the meeting.
