DHSA3 to DFEV. Couple of questions... well... one question.
cbrewer13
Post by cbrewer13 »
I have a 73 with a mechanical fuel pump. is it a problem to block the fuel return?
Re: DHSA3 to DFEV. Couple of questions... well... one question.
no
Ernie
Your car is a: 1978 Fiat Spider
Post by Ernie »
Yeah, maybe. I had to drill a tiny hole in my gas cap so the tank would vent. Could be it was a problem with one of the other hoses going into the tank, but mine was an easy solution.
Ernie
scarlson
Your car is a: 1976 Spider - sold
Post by scarlson »
Hey Mark, what problem could be caused by blocking the fuel return? I blocked the fuel return on when I switched to a DFEV on my 78 with mechanical fuel pump. Did I do something wrong? It ran fine.
76 FIAT Spider - Sold
cbrewer13
Post by cbrewer13 »
Thanks all!
I thought it would be ok, but having an odd duck spider, i thought i should ask first.
I've never experienced any issues with blocking the fuel return. It's not used as a vent for the fuel tank.
