Engine Swap Question
97expedition
Post by 97expedition »
I just purchased my very first Fiat. It is a 1981 Spider Pininfarina. Body is in great shape, interior is fair, but the engine has a hole in the block the size of a softball on the back drivers side. I am having a hard time locating a cheap 2.0l block to rebuild my engine with. So I was thinking about a v8 swap. I have heard about people running a 302 in these cars. Does anyone know what engine mounts I would use to accomplish this or if there is anything I need to watch out for? I plan on running a 302 mildly built engine mated to a T5 5speed trans. Hoping someone on here can help me get started in the right direction with this project.
halg
Re: Engine Swap Question
Post by halg »
As an owner of a V8 powered Fiat Spider my suggestion is don't do it. I first tried it as a bolt in , and the sheetmetal of the engine compartment won't take it. See my post under custom, what's underneath. Where are you located? Even though the car is a blast to drive with way too much horsepower, I wouldn't suggest it as viable project.
Hal
97expedition
I appreciate the advise. I am located in Jackson, Michigan. I am really hoping to find a block I can use to rebuild the stock engine. Would like to keep everything fairly stock.
engineerted
Your car is a: 1974 124 spider
Post by engineerted »
Check out Craigslist
http://detroit.craigslist.org/okl/pts/1655065303.html
I have not see or talked with this guy but may be a good parts car for you. There are alot of Fiat guys here in Michigan, check out the local chapter of FLU. http://www.westmichiganflu.org/
Ted
Ted
