I don't know the correct names for these parts - I lost a clip that connects the throttle/engine mechanism arm to the carburetor. There is a ball that seats itself in the arm/lever and the lost clip covers and holds the lever in place.
You can see the location of the lost clip by the temp white zip tie fix.
I need to find out what these clips are called? Are they Fiat specific? Any vendor that would stock replacement clips?
Does anybody have a fix that they've use for these lost clips?
Thanks guys!
Martin
Need Info About Lost Clip
- maytag
Re: Need Info About Lost Clip
they should not be fiat specific, as that's a fairly common way to attach linkages of this sort.
Your "HELP!" corner at your local autoparts store may have 'em. or hit-up Peirce Manifolds online (Google knows how to contact 'em)... they should have 'em too.
- SLOSpider
- Your car is a: 1973 124 Spider 2.0FI
Throttle linage clips and should be able to drive down to your local napa and get the size you need.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Throttle Linkage. Throttle Linkage Clips.
Got it. Got em'. Thanks!
