I conquered a carburetor!
SquareGrouper
Post by SquareGrouper »
Here's my initial post: http://www.fiatspider.com/f08/viewtopic.php?f=13&t=9080
I had previously replaced the fuel line and drained the tank to get rid of any old fuel and bad line and was on to the carb issues. Found the rebuild kit at a local import shop so I went to town on the carb. Got it all cleaned and back together and she fired right up and sounded 90% better :D Chased down and repaired a couple vacuum leaks and she's purring now!
Decided then to tackle the fuel gauge issue, pulled the sending unit from the tank to find the ethanol demons had done their job :twisted: Meticulously cleaned the sending unti up and re-installed and Viola! we have 1/2 tank of fuel!
Wife is stoked and ready to roll to work a couple days a week with the top down. Mission accomplished. :D
Here's a few vids of the car running smooth!
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: I conquered a carburetor!
Post by wachuko »
Idle spot on! And engine looks running smooth Image
Love the driving video. Image
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
ga.spyder
Post by ga.spyder »
Congrats,the car sounds great.Is that the factory clock?It looks different from any I have seen,and I really like it.If not original,do you know where it was sourced from?
Craig
Craig Nelson
Fling It Around Turns !
Ken
Post by Ken »
http://www.docskustom.com/page154.html
i think the clock is on this page
Ken
obdulio39
Post by obdulio39 »
what kind of vaccum leaks did u experienced? my 80 spider (carb) 34adf runs; but not smooth as it should; so I think. It starts right up; then the idle goes down and its gets better when it warms up; then it stays at 1000rpm or higher. any ideas. thanks
