new vaccum adavance valve
Help!! my 80 spider was running good, til I found out the diaphram on the advance was busted. Replaced it and now the engine runs rough/slow/sluggish and stalls; (hard to crank).
Re: new vaccum adavance valve
sounds like you got the timing off during the re-install
- manoa matt
When you set the timing, unplug the unit and plug the hose. Plug it back in after timing is set.
- maytag
obdulio39 wrote:Help!! my 80 spider was running good, til I found out the diaphram on the advance was busted. Replaced it and now the engine runs rough/slow/sluggish and stalls; (hard to crank).
where'd you get the new advance unit / diaphragm?
