FUEL PROBLEMS
TRASHCAN
FUEL PROBLEMS
Post by TRASHCAN »
HAVE AN 80 PININFARINA,BELIVE IT HAS FUEL PROBLEMS. HAVE HAD INJECTOERS CHECKED OUT . ARE FINE. INSTALLED NEW FUEL PUMP, NEW FUEL TANK, NEW FUEL FILTER, STILL FALLS ON ITS FACE WHEN STEP INTO IT. ANY SUGGESTIONS?
manoa matt
Re: FUEL PROBLEMS
Post by manoa matt »
If it has problems, then what are the symptoms? Always check out the ignition system before moving on the the fuel system. Its components are cheaper, and is usually the fault.
