oil pump pulley position?
deacon
Post by deacon »
I am finishing the replacement of the timing belt, tensioner, water pump, et. I wondered if the oil pump pulley has to be positioned (turned) in a particular position based on a mark on the pulley. If so, why is that? There is a reference in the shop manual I have to position it at 32 degrees if I remember. Sorry if this is a odd or dumb question. The Fiat continues to be a great "educational" tool.
Re: oil pump pulley position?
the aux shaft position is important due to the fuel pump lobe. I align the pulley mark with the tensioner pivot bolt, approx 1 o'clock
deacon
Post by deacon »
Thanks Mark. What would be the result of it not being in the right position?
spiderrey
Post by spiderrey »
It will hit the crank and put a nice hole in the block. If ever the block is apart , you can cut the lobe off the shaft and set that pully anywhere,
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
deacon wrote:Thanks Mark. What would be the result of it not being in the right position?
Here, let me show you: http://www.fiatspider.com/f08/viewtopic.php?f=5&t=8938
Aux shaft end
This engine block is toast? or can that be welded? :?: ...
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
deacon
Post by deacon »
Ouch.....
wachuko
Contact:
Post by wachuko »
deacon wrote:Ouch.....
And that is just the block. I was told that the connecting rod that hits the aux shaft could also suffer damage. I have not check mine closely ... will do so in the next few days as I start working on it again.
Drive Safe!
Wachuko
2015 FIAT Abarth
