Anti- Rattle clips... Which is correct?
What is the correct install procedure for the rattle clips. I have seen documentation that shows just one on the pad bottom, then one on top & bottom then one with top & bottom plus the spring? I have new springs for my front calipers but only have the clips for my rears. Thanks much....
Re: Anti- Rattle clips... Which is correct?
One or the other, not both.
Single spring on bottom or two clips on side.
