Leaky Transmission
- red107
- Contact:
Leaky Transmission
Today I decided to tackle my leaky transmission. I also had a stripped threads on of the bolts holes. well I removed the pan Drilled out the stripped hole and put a helicoil in it. The bolts are 6mm by the way. After that I put on the new gasket and tighten everything up filled the transmission and went on a test drive. Drove about 15 miles. After I returned home I let the car sit for about 5 min Then moved it into the garage and notice a small spot on the ground about 1.5 inches in dia. Damn thing is still leaking . Is there a better gasket then the cardboard style that they sell? Am I missing something? I read the post about not using RTV/gasket maker. Any ideas?
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
Re: Leaky Transmission
there are other spots in can leak from. I believe the cardboard gaskets are the best. Was the pan flat? no raised areas around the bolt holes?
- red107
- Contact:
Yes the pan was flat. Prior to gasket replacement it was leaking in the rear of the pan. but I had a stripped bolt hole there also. I repaired that. Now that you mention it. it could be leaking at the case. I did check those nuts and they were tight.So Cal Mark wrote:there are other spots in can leak from. I believe the cardboard gaskets are the best. Was the pan flat? no raised areas around the bolt holes?
