A few cars I have seen have this two bolts sticking out of the side of the engine block. What is mounted there? A/C compressor??
What is supposed to go here??
- wachuko
- Contact:
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Re: What is supposed to go here??
I believe that would have been for the smog pump. Do not take out the remaining bolts as one of them will leak oil.
- Europa
- Your car is a: 1983 Pininfarina Spidereuropa
My '83 used those studs for the A/C bracket. If you take out the studs, you'll have a nice oil puddle when you run the engine. Son't ask me how I know!
1983 Spidereuropa
Verde Scuro
Verde Scuro
- wachuko
- Contact:
Cool, thank you.
kuhndg wrote:I believe that would have been for the smog pump. Do not take out the remaining bolts as one of them will leak oil.
- red107
- Contact:
A/C mounting bracket mounts there. That 78 I am working on had the compressor mounted there.
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
Originally my alternator went there now they are used for my supercharger
Hal
Hal
- wachuko
- Contact:
errr, you post that and no photos? What kind of tease is that! <on to search the forum for photos...>halg wrote:Originally my alternator went there now they are used for my supercharger
Hal
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- Your car is a: 1981 Spider Turbo - missing the turbo
On my car that's where the turbo mounting bracket attaches.
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
2014 Abarth "SS"
Wachuko, Don't stop when you find the thread about Halg's turbo project, keep looking until you find his V8 Fiat Spider too.
Thats the location for the 40 amp alternator that they stopped using. But its great for racing because there is less drag on the engine. You might go from 77 horsepower way up to 79 horsepower. Now thats technology
- wachuko
- Contact:
What! That is just insane! Weight would be an issue, would it not?rlux4 wrote:Wachuko, Don't stop when you find the thread about Halg's turbo project, keep looking until you find his V8 Fiat Spider too.
Found the supercharger photos... wow! Link to thread
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
yup!
we all have a habit of speed reading coupled with the erroneous assumption that EVERYONE's Fiat is exactly the same as their's. carefull reading of the original post would have revealed that this was an '83, which never had a smog pump, and always had the alternator on the driver's side of the engine.
great job wachuko! pop quizes are great things this time of year. keeps the cabin fever from setting in full blast. even though you originally fell for the wrong answer, don't miss the advice that removing the studs could cause a catostrphic loss of precious lubrication.
i use one of those studs as a mounting point for my secondary grounding cable. Every Spider should have a secondary grounding cable.
Just chiming in- My '74 has the alternator mounted to those studs. My smog pump was mounted to other points, not those 2 studs. Also, my '74 doesn't use the external thermostat. I'm sure an '83 is a completely different setup, though.
