more guessing games
more guessing games
okay kids, here is todays' guessing game. Tell me what the pic is and what caused it. I know the answer to it, so I'll be curious to hear the suggestions. Sorry the pic isn't a little better but it was taken in diminishing twilight.
narfire
Re: more guessing games
Post by narfire »
Melted dist cap. Acid or heat?
knightdalejb
Post by knightdalejb »
distributor that had bad bearings?
ga.spyder
Post by ga.spyder »
That thing must have a really hot coil ! :shock:
Craig Nelson
Fling It Around Turns !
Ken
Post by Ken »
broken rotor
pope
Post by pope »
Toyota Prius brake pedal
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
Melted distributor cover... caused by a bad CDI box or coil?
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Definitely a distributor cap. But what caused it? Did a tube from the heat riser fall on it?
Ron Luxmore
rlux2n2@gmail.com
good guesses, except for the stab at poor ol' Toyota. It's definitely a dist cap from an electronic distributor running a high output coil (about 40k volts max). The coil wire slipped out while the owner was driving, and the spark was strong enough to keep jumping the cap. The arcing kept eating away the contacts until the cap caught on fire. Once the fire melted the cap down onto the rotor the engine quit. It appears the spark was jumping about 2 inches at the end of the event. The owner reported he noticed just a slight hesitation when accelerating before the car died. Luckily, no other damage other then the cap, rotor and coil wire
amsiegel
Post by amsiegel »
Aww I did not get a chance to guess
Of course my guess would have been either0" It was Profesor Plum in the Kitchen with a Rope" or something to do with bigfoot.
