Here's the skinny: car runs fine, stop to fill up with gas, runs rough. Get it home change fuel filter, notice I didn't tighten condensors on distributor after changing valve cover gaskets. Car now runs fine, take it for a little ride, get home, park it in garage. Next day, it won't start. Can pour some fuel in carb and it will fire then.... dies.
Any ideas?
carb help?
Re: carb help?
if the carb drains overnight you need to replace the accelerator pump diaphragm.
Re: carb help?
Mark,So Cal Mark wrote:if the carb drains overnight you need to replace the accelerator pump diaphragm.
got it fired up today. Primed the carb and after 7-8 tries stayed running, fuel filter filled up, and took it out for a spin. Will check tomorrow to see if the issue arises again. If so I'll check out the accelerator pump.
BTW it has a slight hesitation when revving, from idle to about 2k, any ideas?
